KEIHIN 37mm CR SPECIAL CARBS CRMC
Advertise your BIKES and PARTS here
london calling
#1 PostAuthor: london calling » Tue Feb 20, 2018 6:43 am
Set of Keihin CR SPECIAL 37mm smoothbore carbs.
Suitable for large air cooled 4 cylinder engines Z GPz GS GSX,etc
Adjustable spacing.
In very good used condition.
Period racing carbs,CRMC eligible.
£750 cash on collection from Loughborough LE11 5AS
Jack
Pipes66
Re: KEIHIN 37mm CR SPECIAL CARBS CRMC
#2 PostAuthor: Pipes66 » Fri Apr 13, 2018 1:34 pm
Are these still for sale as I'm thinking about doing an 1170?
Cheers Pete
Robw
#3 PostAuthor: Robw » Fri Apr 13, 2018 5:06 pm
Might be too big for an 1170, i have 33mm crs carbs on my 1170 and that gets bogged down at low revs. 35mm are good for top end and 33mm for low down grunt.
Rob
london calling
#4 PostAuthor: london calling » Sun Apr 15, 2018 5:16 am
Hi Pete,yes the carbs are still available.
As you are fairly local,if you want to have a good look at the carbs,that's no problem.
cheers,
Jack
Jack
Return to “For Sale”
