Steel box section braced swing arm
Advertise your BIKES and PARTS here
z1000puddin
#1 PostAuthor: z1000puddin » Mon Apr 16, 2018 2:14 pm
Not 100%sure what this is off of.
It looks to be either JMC or Metmachex
Not ally, it’s steel.
Has the ecentric bosses.
No bearings fitted.
It’s 231mm at the pivot
It’s 248mm inside between the wheel bosses
I assume it’s possible if a zed 1000J ??
But not sure
Looking for £65+ postsge
Zed til Dead
Coose
Re: Steel box section braced swing arm
#2 PostAuthor: Coose » Mon Apr 16, 2018 8:35 pm
That will be a Davida to fit a Z1000J, Z1000R, Z1100R or GPz1100B. Other than your eccentrics being anodised blue it's identical to the one in my J (before I modified it).
Z1parR
#3 PostAuthor: Z1parR » Mon Apr 16, 2018 8:40 pm
Yes Stu as Coose has just said , it's one of Mr. Fiddaman's specials .
0172 . Geoff Parr
Coose
#4 PostAuthor: Coose » Mon Apr 16, 2018 9:04 pm
And, it's probably the one single item that made the biggest improvement to my chassis, so £65 is an utter bargain! :)
8 Valve Mark
#5 PostAuthor: 8 Valve Mark » Tue Apr 17, 2018 1:19 am
hi puddin i could probably utilise it mate. is the wheel spindle hole standard Kawasaki size? cheers mark..
8 Valve Mark
#6 PostAuthor: 8 Valve Mark » Tue Apr 17, 2018 1:29 am
just a thought gents;didn't davida upgrade/double-up the pinch bolts for the eccentric wheel/chain adjusters?at some point? hmmm..
Coose
#7 PostAuthor: Coose » Tue Apr 17, 2018 5:53 am
It uses a spindle which has a keyway and an M18 nut at each end. One eccentric has two M4 grubscrews inside to slot into the keyway, where there should be a key in the other end. It's quite a lot longer than the stock spindle, where on mine I had to space even a stock wheel though there's a possibility that mine was made for a different wheel?
Mine has single pinch bolts and has not been a problem.
z1000puddin
#8 PostAuthor: z1000puddin » Tue Apr 17, 2018 11:29 am
Thanks Guys, What a world of knowledge there is on here :D
Mark,
I will check tonight & replay
Stu
Zed til Dead
Big Fluff
#9 PostAuthor: Big Fluff » Tue Apr 17, 2018 4:12 pm
Here's a Davida Moto on my old 'J' which has twin pinch bolt arrangement.
Kawasaki GPz750T, Kawasaki ZRX1100R, Kawasaki GPZ1000RX, H**** VF1000RG Rothmans, H**** VF500F2F, H**** CB1100RD, Suzuki GSX1100EFE, H**** XL125K2
z1000puddin
#10 PostAuthor: z1000puddin » Tue Apr 17, 2018 8:18 pm
Mark
It is 18.5mm hole , that would be to suit the M18 spindle
It has the keyway & the 2 x m4 tapped holes on the ecentric adjusters
Zed til Dead
z1000puddin
#11 PostAuthor: z1000puddin » Wed Apr 18, 2018 11:58 am
If No Takers, I will put it on evil bay.
I am going to clear ALL the spares that I have shortly for the 1100r jigsaw puzzle that I bout as its nearing the end of the build.
I will be moving house, so everything will be going
Zed til Dead
garyd
#12 PostAuthor: garyd » Wed Apr 18, 2018 4:30 pm
I'm not renting a van again!!!
z1000puddin
#13 PostAuthor: z1000puddin » Thu Apr 19, 2018 11:35 am
HA HA HA
Why not Gary, you got a very good deal the last time :D :D :D
Zed til Dead
Return to “For Sale”
Users browsing this forum: No registered users and 90 guests
