Kipkawa Z1000S Lawson Oil Cooler Mount
Advertise your BIKES and PARTS here
martinz1000r
#1 PostAuthor: martinz1000r » Tue Jan 01, 2019 4:34 pm
13 row Oil cooler mounting bracket original produced by the now defunct KipKawa. Replica of the bracket used by Kawasaki on the Z1000S. Bolts to where the horn bracket attaches to the frame. Holds standard size 13 row cooler (Earls, Mocal etc). Virtually new. I fitted it then changed my mind and used a Tomforde version of the same thing. Slight flaking of surface finish on the top mount but otherwise A1.
I think this was close on £80 new so I think £40 plus post is fair.
Gus
Re: Kipkawa Z1000S Lawson Oil Cooler Mount
#2 PostAuthor: Gus » Tue Jan 01, 2019 6:46 pm
Yes please Martin.
can you pm me payment details
Gus
"Set the GRINDER on it"
martinz1000r
#3 PostAuthor: martinz1000r » Tue Jan 01, 2019 6:56 pm
Gus wrote:Yes please Martin.
Gus
Will do Gus! Will be later this evening
Return to “For Sale”
