Widened front wheel from Deget 3,5x18”
Advertise your BIKES and PARTS here
Mathh
#1 PostAuthor: Mathh » Wed Aug 07, 2019 9:36 pm
For sale as I removed this from one of my builds and have no use for it. I believe it is from a Voyager 1300 and resembles the later model wheels as used on the J type and others. It has been mounted on the Z1000ST currently converted to look like a MK2. It had been fitted to a ZRX1100 front fork and comes equipped with two ZZR1100 320mm brake discs on home made carriers using Micron floaters. Axle diameter is 25mm. The discs and wheel are in great shape. Needs one new wheel bearing..
Widening one now is very expensive (check out http://www.deget.com) Wheel including the discs, carriers and floaters are sold for 300 euros including shipping to the UK (insured and signed for).
Mathh
Re: Widened front wheel from Deget 3,5x18”
#2 PostAuthor: Mathh » Wed Aug 07, 2019 9:38 pm
Some more pictures .. width compared to ST forks ..
Return to “For Sale”
