*** Provisionally sold ***
As many of you will know I organised a group buy with Busso for some of their 4/2 exhausts and it was all a bit of a saga.
I still have a set I bought which have a manufacturing issue (surprise, surprise) and gave up on Busso replacing them and I am never going to use them.
The issue is to do with the angle of the two outlets on the silencers which connect to the balance pipe. They are at slightly the wrong angle and you would either need to fab up a different shaped link pipe or maybe alter the outlets. Not an insurmountable problem for someone.
Looking for £450 which is less than I paid.
Cheers.
Provisionally sold:Busso 4/2 repro exhaust for Z1000A1/2
- warren3200gt
Re: Busso 4/2 repro exhaust for Z1000A1/2
Bit of flex pipe cut to length would sort it easily enough.
Not stock but functional and unseen when fitted.
warren3200gt wrote:Bit of flex pipe cut to length would sort it easily enough.
Indeed. Easy enough to do.
dave cullen
