I will be doing a bit of auto jumble at the Stafford Show so for anyone attending this is a list of jumble with ticket prices based on usual Stafford haggling. If anyone sees anything they might be interested in come and find me in the Prestwood Autojumble Hall Saturday or Sunday and have a look. This is not a for sale ad just a list of auto jumble I'll hopefully be taking to try and clear space in the garage. Mostly Kawasaki. Cleared this post with Admin
Stafford Autojumble.
Blue anodised alloy bars £5
Bultaco Artein ex. gasket P012000000710 new £20
Hodna Xrv750 owners manual (wiring diagram etc.) £20
Hodna VFR petrol cap with key £25
Mini indicators set smoked £20
Kawasaki Big Four Heavy Duty rear engine mount Z1/Z1000 £25
Kawasaki Z1b sidepanels genuine £50 ea
Kawasaki Z1B tail genuine £70
Kawasaki Z1B tail light bracket chromed (Uk bike) £30
Kawasaki Z1B booklet tray 32099-010 and 92074-024+ book £60
Kawasaki 500/ZIB caliper hanger 43044-004 £10
Kawasaki 500/Z1B caliper slider shafts 43045-003 £10
Kawasaki Z1B shocks April 1974 Uk bike need refurbed £100
Kawasaki Z1B mudguard mount 35026-006 and 92075-132 £40
Kawasaki Zx7 stem triple tree £20
Kawasaki KH 250 switchgear (parts) £15
Kawasaki S1 S2 S3 KH Triple Rear Brake Drum hub and brake £90
KH 250 sprocket carrier S1 S2 S3 48T (250) sprocket £40
Kawasaki 250/350 baffle ? £20
Kawasaki H1 H1A rear brake cable grey (replica) £25
Kawasaki H1/A/B Wheel and hub + brake plate £150
Kawasaki Z1000 15t 630 std sprocket
Kawasaki z1000 A1 fork cup £ 5
Kawasaki Z1000 clutch pusher 13116-022 £10
Kawasaki 2x exhaust clamps 18069-063 £10
Kawasaki Z1000 A1 rear pegs 92076-027 brackets 32054-1021 £20
Kawasaki Z1000 sidepanel genuine £40 ea
Kawasaki Z1000 points plate complete genuine March 77 date £25
Kawasaki Clock covers (genuine) chromed scruffy
Z900 1000A1/A2 £10
Kawasaki Z1000 A1 fork leg £40
Kawasaki Z900 Z1000 instrument light cover £20
Kawasaki Z1000 A1 generator rotor and starter clutch £150
Kawasaki Z1000 A1 stator £70
Kawasaki Z1000 A1 alternator casing £40
Kawasaki Z1000 inner mudguard £5 +15
Kawasaki Z1-R battery box £50
Kawasaki Perforated arrester GPz £5
Kawasaki Z1000 l/h footrest 34028-011 and bracket 34003-036 £30
Kawasaki Z1000 A1 crankshaft £120
Kawasaki 1000R front mudguard (cut about) £10
Kawasaki Z1000 A1 front and rear fibreglass mudguards £50
Kawasaki Z1000 A1 mudguard mount and rubber £30
Twin rear light setup £20
Kawasaki 1000R fork cups pair £10
Kawasaki 92093-1051 Dust cap 1000R GPz others (used good) £ 5
Kawasaki Z1000R Kerker headers £50
Kawasaki NOS Z1000 J/R/GPz number plate bracket
11034-1922 (non reflector type) £20
Kawasaki Top Yoke 44039-051 250 S2A/S3/KH400 £60
Kawasaki Top Yoke 44039-1022 Z750/650CSR/others £20
Kawasaki 1000R rear footrest left 34028-1041 £15
Kawasaki Indicator stems 3x £10
Kawasaki J/R generator rotor and starter clutch £100
Kawasaki Cam parts
13091-1084 and 13107-1020 £7
92057-1319 cam chain new £25
12053-1048 front guide good £15
12053-1049 rear guide new £25
Kawasaki Z1000 1972-1978 219T 122L Z1-Z900-Z1000
Tourmax cam chain with link NEW £35
Kawasaki Z1000 A1 cam chain tensioner good £40
Kawasaki Z1000 J/R cam chain tensioner £40
Kawasaki Z1000 A1 cams standard pair £75
Kawasaki Z1000 A1 top idler and wheels used but ok £50
Kawasaki ZRX1100 torque arm £20
Steel brake hose £10
Suzuki Swing arm GSX ES ET 1980-83 £70
Suzuki GSX-R750J 1988 torque arm £30
Suzuki Wheel 4.5 Bandit 60 with Cush disc and sprocket £50
Suzuki indicators pair 35603-70 £25
Suzuki Bandit 1200 rev counter NOS cover 34211-26D01(NLA) £60
Suzuki GSX axle 325mmx20mm £20
SW shocks 350mm Z1/Z1000 £40
Triumph original Veglia clocks, speedo and tacho
now hard to find, fitted as std. to later model
T140E/ TSX etc., will also fit Triumph T160, TSS £70
T140 TR7 primary chain case cover £50
Yamaha TDR 250 Forks spares/repair £75
Yamaha TDR 250 exhaust shields some marks on one, crack on one £30 three
Stafford Show Autojumble 11th 12th October
- paul doran
Re: Stafford Show Autojumble 11th 12th October
Chris I will take the 1000R fork cups
I'm at Stafford on Saturday. Would like Kerker 1000R headers if they are still for sale.
Z1000R2 ZR1100A1
paul doran wrote:Chris I will take the 1000R fork cups
No worries Paul
Lynd44 wrote:I'm at Stafford on Saturday. Would like Kerker 1000R headers if they are still for sale.
Sent you a PM
