A set of carbs that came to me with the balance adjustment bar and hardware cut off the main carb holding plate, hence sold for spares or repair. Apart from the above, all the carb bodies are in good used condition with no damage, nothing seized.
Marked 217 which I believe is for the z1b.
£250 collected from Whitchurch, Shropshire. Postage will be around £20 tracked, within the uk.
Z1b carbs spares or repair
