Top shock mount extensions
Advertise your BIKES and PARTS here
Graham-A2
Re: Top shock mount extensions
#31 PostAuthor: Graham-A2 » Thu Sep 28, 2017 3:58 pm
Hi Stempy - sorry dumb question. What advantage do the extensions give ? Wider choice of shocks ? Different swinging arms ? Thought if I don't ask I'd never know :biggrin
Present
Red '78 KZ - rebuilt from engine up
Other wheels - Couple of old Guzzi's
Past 1994 - 2010
Luminous Green '78 KZ import [BLE 656S]
FER
Auld Heedyun
#32 PostAuthor: FER » Thu Sep 28, 2017 4:29 pm
If you fit a wider swing arm the lower shock mounts are moved further apart . These move the top shock mount out to compensate .
fer
stempy
#33 PostAuthor: stempy » Sun Oct 08, 2017 11:59 am
Who wants the last set ??
PUM 451
FOZ1A
#34 PostAuthor: FOZ1A » Tue Mar 13, 2018 4:45 pm
Any chance you have a set knocking about, if not will you be making any more?
Foz
stempy
#35 PostAuthor: stempy » Tue Mar 13, 2018 4:53 pm
Just so happens I think I have 1 set left
PUM 451
FOZ1A
#36 PostAuthor: FOZ1A » Tue Mar 13, 2018 9:10 pm
If you do, i will have them off you, PM me you payment details.
foz
Charlie
#37 PostAuthor: Charlie » Sun Apr 15, 2018 12:43 pm
Will you be making any more of these ? I have a set of 20mm but could do with 25's :(
stempy
#38 PostAuthor: stempy » Mon Apr 13, 2020 7:42 am
Anyone interested in the Shocker mount extensions ,ready to start another batch should be ready next weekend .
Stempy
PUM 451
engz1b
#39 PostAuthor: engz1b » Mon Apr 13, 2020 12:16 pm
I will have a set please, have sent you a pm , thanks richard
Charlie
#40 PostAuthor: Charlie » Mon Apr 13, 2020 3:33 pm
I am interested, but is it possible to get a shorter set made up. Basically I need a set that just extends by maybe 25mm over the stock set up, or roughly the length of threaded portion again along with the back spacer
I have a Zephyr swingarm and its only that much wider each side than stock. I have the long set - but they are too long :(
stempy
#41 PostAuthor: stempy » Mon Apr 13, 2020 6:02 pm
Charlie
Normally people fit the 20mm extensions when fitting a ZRX arm ?
Stempy
PUM 451
Charlie
#42 PostAuthor: Charlie » Tue Apr 14, 2020 9:29 am
Yeah, mine is a 650, and I have a Zephyr 400 swingarm.
I only need to extend my current frame mounts by 25mm overall, that's the thing mate, not 25mm and then the thread if that makes sense ?
I can get the shocks on with a spacer fitted on the frame side as it sits, but not enough room left on the thread for the grab rail, or even a full nut - its all too close to be comfortable really. I kinda need 10mm of additional extension plus a further 15mm of thread.
A stubby version of what I had last time.
If that isn't doable, no problems :)
stempy
#43 PostAuthor: stempy » Tue Apr 28, 2020 6:29 pm
Thanks for the response so far 6 sets left
Stempy
PUM 451
rpeters
Bristol's "H" Hoarder
#44 PostAuthor: rpeters » Wed Apr 29, 2020 8:41 am
Can I have a 20mm set please
Rob
paid up member
kawasaki_man
#45 PostAuthor: kawasaki_man » Wed Apr 29, 2020 8:50 am
Please can I have a set.
PM sent
Return to “For Sale”
