These have been recently used on my own zed whilst running it in. Since i have now aquired some RS Flatslides, these are no longer required.
Vapour blasted, ultrasonically cleaned, rebuilt using new gaskets, jets, needles etc. Some threads are now heli-coiled, stainless cap heads throughout, new brass delivery t-peices.
Lots of parts have been zinc plated and polished by Mikey.
They have been fitted with home-made air corrector jets made from Nylon to correct running issues just off idle for pod filters. If you dont want these, they can be easily drilled out. Works well but will require final jetting for your application.
The fuel enrichment circuit is a bit worn so is very rich on choke, but fine once off.
Lots of parts as well. Jets, needles, gaskets, float valves etc.
Looking for £300 plus post
I also have the pod filters and inlet rubbers
Mikuni VM26's
- Zomerset Zed
Mikuni VM26's
