Dyna S ignition
Advertise your BIKES and PARTS here
martinz1000r
Dyna S ignition
#1 PostAuthor: martinz1000r » Sun Jan 13, 2019 11:02 am
Dyna S ignition removed from my Z900. What you get is as per pictures. Fully functioning and only removed because my 1260 motor runs such a high compression that it needs a custom map that one can only do with Dyna 2000. I dont have the instructions but i think they are a download from the Dynajet web site or i can copy the instructions from my Katana which has same system and i suspect exactly the same fitting instructions. Price is £95 including post to UK mainland, fully insured via Parcelforce.
Return to “For Sale”
Users browsing this forum: No registered users and 1 guest
