Shamelessly pinched the pics from the last time this was advertised by someone else not myself dry build use only rear wheel complete for Z1 Z900. The wheel was built by CWC they polished the hub fitted stainless spokes and an 18 inch 4 1/4 rim with new 160 Bridgestone tyre. This comes with the brake plate (freshly polished by Mikey) the lever shown plus the sprocket carrier and inner spacer new bearings fitted also includes new cush drive rubbers Looking for £460 posted UK. I have the item boxed hence using the original pictures,,, pickup welcome in the north east. This item has not been fitted so no wear.
drum rear wheel 18 inch 160 tyre
GPZ1100 A1 zrx1100 gsa1200
Re: drum rear wheel 18 inch 160 tyre
Hi .
I'm quite new to here and not really sure what I'm doing.
Is this still for sale?
I'm building an a4 and struggling with rear wheels!
Regards
Tim
Regards
Tim
Z900a4, BMW 1200GS, KTBFFH
tim.25 wrote:Hi .
Regards
Tim
Nice wheel but not if you're doing a standard build.
Hi guys,
No I'm not doing a standard build, using a dresda box section
With piggy back shocks.
It's going to be a keeper for me, so I will probably change things over the years.
Hi Tim. Yes it is still for sale pm me if you want to chat
I have tried to send a pm , not sure if it went as I'm not a paid up member, do I have to pay before I can send a message can someone enlighten me?
Tim, you should be able to send PM's, but they will stay in your outbox, until it's opened by the recipient.
No problem Tim got through and we have spoken on the phone
Still for sale 400 for pickup due to weight 460 delivered uk address. note this does not fit a standard swinging arm. More for a jmc dresda. Etc. Last chance before I break it which will be a shame as it is a nice looking combo. Ibeleive you can also use a zrx11 swinger
