REDUCED! :wiseco 1075 conversion
- 8 Valve Mark
1015 barrels,(72mm forged pistons@10.25:1cr)with new wiseco liners, professionally fitted, bored,piano wired, and honed:, wiseco forged pistons, rings, pins n circlips..only 1,100 careful miles under 6,000 rpm.ASSURED.one v. v. very small chip to 1rear fin which is almost invisible.fit n forget..all in; about £1100 cost including purchase,import duties, shipping n machining etc.£650 + post.no offers thanks pm/email for pictures, info etc. cheers m
- 8 Valve Mark
Re: wiseco 1075 conversion
REDUCED! on behalf of the owner:£550! plus p+p!! bargain for the cost of the pistons alone. m
Re: REDUCED! :wiseco 1075 conversion
will these fit z1000J?
drew
drew
- ZedHead
sure the small ends are different sizes on the conrods ?
1015 barrels won't fit the 998 J without modification for the slipper tensioners..
You could use the pistons as they are the same 17mm pin but the pin sits higher in the earlier 1015 pistons than the J and the 1015 block is taller so you would lose compression which would require a shortened J block to compensate.
trikerdrew, you have PM.
