z900 cylinder head with cam caps had some thread repair, all good now, no valves. usual crakes between plug and valves
All plus postage from Belfast to you all prices negotiable
Cylinder head £150
engine bars need a good clean, with long engine stud £45
Z Power new left metal brake pipe £12
Front spindle and spacer £15
Torque arm stamped painted so needs rechrome £10
Rear sets, look sorta home made sorta not , need rechrome £60
more 900 parts cylinder head
Re: more 900 parts cylinder head
Rear sets sold
Hi
Did you get my last PM re the engine bars and back axle?
Just as info. I have a head with 8 separated bearing caps. Assume that’s a earlier 900
- 8 Valve Mark
jonhunt wrote:Just as info. I have a head with 8 separated bearing caps. Assume that’s a earlier 900
I've only ever seen 4 caps jon... hmm...how bizzare , how bizzare....
I don't think so, I think it was original to my 76 A4. Maybe someone else can shed more light on it.
Ignore my comment. Had a quick dig around in the garage caps are The same.
