Suzuki GT750 Frame and Engine numbers
Do Suzuki GT750 Frame and Engine numbers have to match to be correct or within a few hundred of each other like zeds? cheers.
Re: Suzuki GT750 Frame and Engine numbers
A1John wrote:Do Suzuki GT750 Frame and Engine numbers have to match to be correct or within a few hundred of each other like zeds? cheers.
Zeds are usually a bit more than a "few hundred apart"
John, apart from the first few bikes in 1972, the numbers are not matched: I have 2 unmolested Kettles and engine and frame numbers on both are about 1000 apart. Frame number should be lower number of the two.
Cheers Tim
Cheers Tim
