First ride
olnmfc
First ride
#1 PostAuthor: olnmfc » Thu Feb 22, 2024 10:48 am
Dry for a couple of days so got the new z650 out for a short ride to St Andrews. Goes well but noticed a bit of a mid range flat spot in the higher gears, suspect need to go a clip richer on the needle
gray
Re: First ride
#2 PostAuthor: gray » Thu Feb 22, 2024 8:28 pm
worth cleaning the carbs out and checking the passages/ pilot airways and making sure all carbs are set up the same (airscrew settings/ jet sizes pilot and main)/ float heights/ clip positions and check ignition timing and whether the advance/ retard unit is advancing when it should ( weak springs will make it advance too soon in the rev range and engine will bog down as it accelerates, mimicking a midrange/ low throttle opening flat spot) and valve clearances and carb balance.
Sorry to give a big list brother
Manual will tell you when in the rev range your ignition timing is normal and by which stage in the rev range it should be fully advanced
gray
