Carb refurbs.
Andy M
Carb refurbs.
#1 PostAuthor: Andy M » Sun Nov 12, 2017 9:47 pm
Has anyone here done a complete refurb on their carbs inc plating the plated parts etc ? Any pics ?/
Re: Carb refurbs.
#2 PostAuthor: PAULJAC47 » Mon Nov 13, 2017 9:04 am
Done a few sets meself,ultrasonic cleaner,all new bits and a local friendly plater(who doesnt loose too many bits)plus patience...viewtopic.php?f=7&t=39637&p=343554#p343554
Did these meself...
walshyco
Re: Carb refurbs.
#3 PostAuthor: walshyco » Mon Nov 13, 2017 12:05 pm
Done a good job there Paul.
Re: Carb refurbs.
#4 PostAuthor: Ultim8pc » Mon Nov 13, 2017 2:11 pm
Did my z900 ones a while back and a set of z1000 ones recently. Ultrasonic cleaner, no replating.
Before:
After:
z900a4
z1000a1 (In bits)
z1000ST (in bits)
z1000Ltd (Project)
ZRX1200r
csx355
Re: Carb refurbs.
#5 PostAuthor: csx355 » Tue Nov 14, 2017 9:04 pm
Just about to start mine - I had two sets of carbs with the box of bits formally known as a Z1000. A 26mm set and a 28mm set. I stripped the 26mm set last night and soaked them today in a Rozone cleaning bath. I just wanted to get the grease and grime off prior to going in my Ultra sonic bath. My intention is to plate and polish as much as I can myself. I have a basic homebrew plating bath based on the Gateros set with some mods.
Sorry the pics got out of sync a bit. They cleaned up really well - just started a little bit of oxidising.
I took the pics for my own reference really - this is the first time I have stripped a bank of four down.
Re: Carb refurbs.
#6 PostAuthor: chrisNI » Tue Nov 14, 2017 9:11 pm
My brother just tarted up the ones on his 650...
Re: Carb refurbs.
#7 PostAuthor: Ultim8pc » Wed Nov 15, 2017 10:15 am
ooooo! Some fine looking carbs here!
z900a4
z1000a1 (In bits)
z1000ST (in bits)
z1000Ltd (Project)
ZRX1200r
Re: Carb refurbs.
#8 PostAuthor: kev edwards » Wed Nov 15, 2017 5:22 pm
Ultim8pc you have put the carbs back wrong the air screws are on the wrong sides of the carbs you need to swap the pairs around.
Re: Carb refurbs.
#9 PostAuthor: Ultim8pc » Wed Nov 15, 2017 9:05 pm
kev edwards wrote:Ultim8pc you have put the carbs back wrong the air screws are on the wrong sides of the carbs you need to swap the pairs around.
Oh yes, so I have....
:oops:
Oh well, I can fit some new fuel T-pieces while I'm at it, so it won't be a wasted effort...
Fanks a lot..
z900a4
z1000a1 (In bits)
z1000ST (in bits)
z1000Ltd (Project)
ZRX1200r
csx355
Re: Carb refurbs.
#10 PostAuthor: csx355 » Wed Nov 15, 2017 9:26 pm
new fuel T-pieces
I'm going to need some of those as well - is there a decent (better priced) option to the originals? If not any recommendations for the brass with replaceable o rings?
chrisw1
Re: Carb refurbs.
#11 PostAuthor: chrisw1 » Wed Nov 15, 2017 9:40 pm
After and before being in the ultrasonic bath
Re: Carb refurbs.
#12 PostAuthor: Ultim8pc » Wed Nov 15, 2017 9:52 pm
chrisw1 wrote:After and before being in the ultrasonic bath
I think you've cheated and pout new jets in...
z900a4
z1000a1 (In bits)
z1000ST (in bits)
z1000Ltd (Project)
ZRX1200r
Mr Bump
Re: Carb refurbs.
#13 PostAuthor: Mr Bump » Thu Nov 16, 2017 8:42 am
csx355 wrote:
new fuel T-pieces
Nrp carbs do them, I think i saw zpower list them too. Much nicer design than the original thingys.
At the risk of hijacking the thread, I’m considering buying an ultrasonic cleaner myself - any advice/warnings/recommendations would be appreciated.
Olly
Lemmy
Re: Carb refurbs.
#14 PostAuthor: Ultim8pc » Thu Nov 16, 2017 2:45 pm
I bought some Kawasaki original items from eBay. Think they worked out at £17 (!) each. Going to try some brass one next time though.
Ollie: buy the best ultrasonic cleaner you can. I can't get all the parts for 4 carbs in mine (even using the old 'plastic tub' extender bodge). It's done me proud but I use it that much I'm probably going to have to buy a bigger one. (Oh and a vapour bead blasting machine and..)
z900a4
z1000a1 (In bits)
z1000ST (in bits)
z1000Ltd (Project)
ZRX1200r
Re: Carb refurbs.
#15 PostAuthor: PAULJAC47 » Thu Nov 16, 2017 3:03 pm
Do Tell, whats the plastic tub extender bodge?
