Z1 Lower Fork Leg Restoration
- Tonka
Gents, when the lower fork legs are showing corrosion, pitting, stone chips etc what is the best and easiest method to restore them so they look the same as when they were new? I don't want highly polished fork legs, they must have the cross grazing and lacquer on them if you know what I mean.
Inheritance? What inheritance? He spent it all on booze, women and Zed parts!
Re: Z1 Lower Fork Leg Restoration
I Glass bead blast mine then scotchbrite them for markings then re lacquer them
good as new
good as new
- 8 Valve Mark
mikey does resto to original finish
Wet & dry the scratches, Scotchpad used in one direction only to get the brushed look finish then a few coats of Lacquer.
