z1 j frame or dare i ask gpz1100 unitrack frame
Im after a frame for my race bike, the frame it has is powder coated, I need to brace and monoshock it and it will be a pain in the arse stripping powder coat, looking for a cheap frame, numbers+v5 unimportant, or a unitrack frame would be even better as I wont need to do the mono shock bit.
If its not broken, fix it till it is
unitrak frame.
Hi F`nuckle,I`ve got a Unitrak frame.I will check it out Wed`and think of a price, if you still need one. Might be easier to phone,07947 848 238.
cheers,Keith.
cheers,Keith.
trikerdrew
ant use??
GPZ1100B1 frame and forks but fitted with Unitrak swingarm and wheels.Swing arm has had twin shock mounts fitted.The green tank pictured is fooked really but a good KZ1100 ? tank is included as is special alloy stilson monoshock .Reg No UNK***W.£80
drew
drew
Re: ant use??
trikerdrew wrote:GPZ1100B1 frame and forks but fitted with Unitrak swingarm and wheels.Swing arm has had twin shock mounts fitted.The green tank pictured is fooked really but a good KZ1100 ? tank is included as is special alloy stilson monoshock .Reg No UNK***W.£80
drew
What picture Drew?
"Set the GRINDER on it"
Re: z1 j frame or dare i ask gpz1100 unitrack frame
fuknuckle wrote:Im after a frame for my race bike, the frame it has is powder coated, I need to brace and monoshock it and it will be a pain in the arse stripping powder coat, looking for a cheap frame, numbers+v5 unimportant, or a unitrack frame would be even better as I wont need to do the mono shock bit.
Rolling chassis
trikerdrew
trikerdrew
nope
Belongs to Ned on that forum.
Seems to be sold now anyways
regards
drew
regards
drew
- mick znone
Re: see if this works
i like that, ive never seen an adjustable rigid frame beforetrikerdrew wrote:http://www.100-biker.co.uk/forums/attachment.php?attachmentid=12489&stc=1&d=1247037603
drew
