spring pins
spring pins
im after two spring pins,or seloc pins,the ones that are split up one side,and are under tention when knocked in,size is,3 inch long by half inch wide,can anyone help out,as the biggest i can find are 9mm wide,by 40mm long.
We use these pins where I work but not in that size unfortunately. However the part is available from Spirol in the size you need
http://www.spirol.com/mkt/rs1.php?search=4
MOQ is 100 though so might be worth phoning them for a sample
- z1000puddin
