Offset front sprocket
harrythemagnum
#1 PostAuthor: harrythemagnum » Wed Jan 09, 2013 11:37 am
Just about to order one, but you never know what members might have spare.
Wanted 5/8" offset, 530 pitch, ta.
What a wonderful philosophy you have,
Gus
#2 PostAuthor: Gus » Wed Jan 09, 2013 12:14 pm
I haven't got one but people will want to know how many teeth and what output shaft fitting.
Gus
"Set the GRINDER on it"
dixiethedog
#3 PostAuthor: dixiethedog » Wed Jan 09, 2013 4:20 pm
evilbay usa. :D You find a few in the dragbike spares section. I bought one stateside for just a few quid,much cheaper than some of the ones here.
If you rich try debben or talon. :D
Every silver lining has a cloud...
stempy
Sprocket
#4 PostAuthor: stempy » Wed Jan 09, 2013 5:07 pm
PUM 451
steve.w
#5 PostAuthor: steve.w » Wed Jan 09, 2013 5:57 pm
gsxr 750 fits straight on to gpz1100j b1 2 etc :idea: :idea:
harrythemagnum
#6 PostAuthor: harrythemagnum » Wed Jan 09, 2013 6:35 pm
For Z1000A1, back wheel is ZZR1100 (530 sprocket), so Talon it is then.
:sad
Gus
#7 PostAuthor: Gus » Wed Jan 09, 2013 6:50 pm
What gear ratio are you going for with the zzr rear wheel diameter and the sprocket size?
Steve Debben has done this chart which is very useful.
http://z1ownersclub.co.uk/forum/viewtop ... gear+ratio
Gus
#8 PostAuthor: Ginger Bear » Wed Jan 09, 2013 7:20 pm
If you want 17t or 18t Debben will be cheaper..........
http://www.debben.co.uk/acatalog/z1000.html (Scroll down)
# 104
750steve
#9 PostAuthor: 750steve » Wed Jan 09, 2013 7:21 pm
You want a STD ZX6R or ZX7, some years of those were offset but i think it was 10mm, could be wrong on that, you'd need to check the chain pitch too
Gus
#10 PostAuthor: Gus » Wed Jan 09, 2013 8:29 pm
Ginger Bear wrote:If you want 17t or 18t Debben will be cheaper..........
Hi Steve
I'm not sure but I think Talon supply Debben.
Cheers.
Gus
harrythemagnum
#11 PostAuthor: harrythemagnum » Wed Jan 09, 2013 8:36 pm
Gus wrote:What gear ratio are you going for with the zzr rear wheel diameter and the sprocket size?
Gus
Spot on, just what I needed, ta.
I'll match the ZZR rear sprocket to what offset front I can source.
#12 PostAuthor: Ginger Bear » Wed Jan 09, 2013 8:47 pm
Hi Steve
Cheers.
Gus
Gus,
They do, but Debben will get a better price on a bulk order. It's probably only worth going direct to Talon if you want a 19t.
# 104
#13 PostAuthor: Ginger Bear » Wed Jan 09, 2013 8:51 pm
harrythemagnum wrote:I'll match the ZZR rear sprocket to what offset front I can source.
If you're planning to fit a 180 tyre, you will need a 5/8th offset front sprocket.
# 104
harrythemagnum
#14 PostAuthor: harrythemagnum » Wed Jan 09, 2013 10:59 pm
Ok, noted, ta.
:fou
Users browsing this forum: Bing [Bot] and 36 guests
