Z1 Centre Stand
DogsbolloxofZ1B
Z1 Centre Stand
#1 PostAuthor: DogsbolloxofZ1B » Thu Apr 04, 2013 10:25 pm
Looking for a clean and straight centre stand, don't mind having it reprinted. But got to be correct for Z1 models.
Anybody got one?
Cheers Mike
pertonpc
#2 PostAuthor: pertonpc » Thu Apr 04, 2013 11:16 pm
Hi Mike,
There is a chap on eBay doing these as repros if you can't find one from a member.
It is not quite the same quality as the factory one though. e.g. the end that shows under the left pipe is less rounded.
wilsonsjw11
#3 PostAuthor: wilsonsjw11 » Fri Apr 05, 2013 1:22 pm
Mike
I know you will probably want OEM but DOREMI do one for about $104.00US with what looks like rougher welding than on an original item :lol:
Available on Doremi site.
Regards
Steve
#4 PostAuthor: z1bman » Fri Apr 05, 2013 1:30 pm
pattern ones are shite the mounting bolts are as loose a a prick in a shirt sleeve. unless you get the stand sleeved or new bolts made to fit it will rattle
KeithZ1R
#5 PostAuthor: KeithZ1R » Fri Apr 05, 2013 1:59 pm
z1bman wrote:as loose a a prick in a shirt sleeve.
genius :hys: :hys: logged for future use
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
steve r1
#6 PostAuthor: steve r1 » Fri Apr 05, 2013 3:37 pm
very true z1bman,and i can add it would be like an extremely small prick in a shirt sleeve as i have one,pattern centre stand that is not an extremely small prick,had to have stand reamed out and some spacers fitted to stop it rattling,no probs now though
74z1a,75z1b,zrx1200r,94 blade,96blackbird,xjr1300
skitz
#7 PostAuthor: skitz » Fri Apr 05, 2013 3:52 pm
I've got one in the garage its complete but just needs a good clean and a re-spray. I'll PM you email address
SKITZ
Kill it with fire
DogsbolloxofZ1B
#8 PostAuthor: DogsbolloxofZ1B » Fri Apr 12, 2013 8:54 pm
Sorted,
Cheers Mike :D :D :D
Z1B
#9 PostAuthor: Z1B » Fri Apr 12, 2013 10:00 pm
I need one myself, and a wiring harness, and......
Always Learning. :wink
Users browsing this forum: davidcouzens and 36 guests
