CARB FLOAT PIVOT PIN - Pleeze
#1 PostAuthor: Pigford » Fri Feb 05, 2016 7:56 pm
Damn & Blast :shock:
lost a float pivot pin out of some Zed carbs... anyone got a spare laying around please :?:
sid123
#2 PostAuthor: sid123 » Fri Feb 05, 2016 9:07 pm
short term use the stem of a twist drill - till you can get right one
whoosh im gone
sid123
#3 PostAuthor: sid123 » Fri Feb 05, 2016 9:11 pm
whoosh im gone
#4 PostAuthor: Pigford » Fri Feb 05, 2016 9:35 pm
sid123 wrote:short term use the stem of a twist drill - till you can get right one
Sounds like a good plan "B" - but gonna try and get the real McCoy, ta :wink:
Z1parR
#5 PostAuthor: Z1parR » Fri Feb 05, 2016 10:15 pm
I'm sure i've got some Mark .
I'm back home on Sunday so i'll have a delve .
Your's for the usual price :wink:
0172 . Geoff Parr
Gavin
Re: CARB FLOAT PIVOT PIN - Pleeze
#6 PostAuthor: Gavin » Fri Feb 05, 2016 11:23 pm
Pigford wrote:Damn & Blast :shock:
Pm your address I will send you a replacement
Z1000 MK2
Z1300 DFI
#7 PostAuthor: Pigford » Sat Feb 06, 2016 8:04 am
Very kind of you both!!!
Gavin.... as you defo have one, I've PM'd you, cheers :wink:
Gavin
#8 PostAuthor: Gavin » Sat Feb 06, 2016 5:00 pm
Pigford wrote:Very kind of you both!!!
It will be the post on Monday
Should be with you tomorrow
Z1000 MK2
Z1300 DFI
