Carb cable bracket
popsA1
Carb cable bracket
#1 PostAuthor: popsA1 » Mon May 01, 2017 9:15 pm
This is probably a bit of a long shot but I need a cable bracket for a set of vm26 carbs. The set I have came from an early GS850 where the push cable mount is a good 15 to 20mm higher. As a result either the inner cable needs to be longer or the outer needs to be shorter by the same amount.
This is what I've got
and this is something like what I want
Paul
A2 1979-80. A1 1980-now
Re: Carb cable bracket
#2 PostAuthor: warren3200gt » Mon May 01, 2017 9:22 pm
Think you might find it easier to find a suitable cable than mount.
popsA1
#3 PostAuthor: popsA1 » Tue May 02, 2017 8:03 am
You'r probably right. If only my welding skills were as good as my photoshop skills.
#4 PostAuthor: paul doran » Tue May 02, 2017 10:44 am
I might have one be Friday before I can look
needaz1100r
#5 PostAuthor: needaz1100r » Tue May 02, 2017 12:02 pm
Mark.
