Z650 Front discs
- RALPHARAMA
Z650 Front discs
I am converting a customers bike to twin discs, but whilst he has a pair of calipers he hasn't got a pair of discs. The discs that came with the calipers are too small in diameter (from memory I think they may have been 275mm and he need bigger 'uns!
Ralph Ferrand
Re: Z650 Front discs
try kawasakiheaven on ebay they specialise in 650s
The 4 bolt fixing Z650 twin discs as fitted to C1/C2/C3 etc are all 275mm O.D.
The B models with a single brake caliper and usually spoked wheels had a larger disc.
I "think" it was 290mm but do not have a definitive reference to hand that says to confirm.
The larger rotors with 4 bolt fixings were fitted to single disc models
H1-D (1973)
H1-E (1974)
H1-F (1975)
KH500-A8 (1976)
Z1000-A1 (KZ1000) (1977)
Z1000-A2 (KZ1000) (1978)
Z1000-A2A (KZ1000) (1978)
Z650-B1 (1977)
Z650-B2 (1978)
Z650-B2A (1978)
Z650-B3 (1979)
Z750-B1 (1976)
Z750-B2 (1977)
Z750-B3 (1978)
Z750-B4 (1979)
Z900-A4 (1976)
Z900-A5 (1977)
The 4 bolt fixing 275mm twin discs were fitted to
Z650-C1 (Custom) (1977)
Z650-C2 (Custom) (1978)
Z650-C3 (Custom) (1979)
Z650-D1 (SR) (1978)
Z650-D1A (SR) (1978)
Z650-D2 (SR) (1979)
Dont forget to upgrade the master cylinder as well ...
HTH
H1-D (1973)
H1-E (1974)
H1-F (1975)
KH500-A8 (1976)
Z650-B1 (1977)
Z650-B2 (1978)
Z650-B2A (1978)
Z650-B3 (1979)
Z750-B1 (1976)
Z750-B2 (1977)
Z750-B3 (1978)
Z750-B4 (1979)
Z900-A4 (1976)
Z900-A5 (1977)
Z650-D1 (SR) (1978)
Z650-D2 (SR) (1979)
HTH
Think the larger Discs were 296mm.
GIMPieZ650
- Regular Poster
I have a 296mm 4bolt disc here if you're interested
296mm IS the Z650B and all the other models I listed single disc. You must be running calipers in front of the forks I'd wager. Those are the calipers that go with the larger discs and vice versa
- RALPHARAMA
GIMPieZ650 wrote:I have a 296mm 4bolt disc here if you're interested
That would be grand. How much would Sir like?
The one on the other side looks like this. Cheers, Ralph
Ralph Ferrand
GIMPieZ650
- Regular Poster
The one I have is un-drilled, and ive no idea what i want for it, make me an offer whats the going rate for a used Zed disc?
Users browsing this forum: No registered users and 73 guests
