RACK FOR Z1000J WANTED
navtrad
#1 PostAuthor: navtrad » Thu Feb 15, 2018 9:33 pm
Does anyone have a rack to fit a Z1000J please?
Regards,
Nigel
Re: RACK FOR Z1000J WANTED
#2 PostAuthor: Al » Fri Feb 16, 2018 5:48 pm
I have one off mine and its sound but over engineered. In fact it is capable of withstanding a rear end shunt. Its painted in silver hammerite which would need to come off. Has the rear mounting bracket. Will get a picture up over the weekend
navtrad
#3 PostAuthor: navtrad » Fri Feb 16, 2018 5:52 pm
Great, thanks Al.
#4 PostAuthor: Al » Fri Feb 16, 2018 8:52 pm
As below.
Its no lightweight and a cautionary note; if you overload it you will snap the short frame extensions off the rear end. Dont know what the design carry weight is supposed to be i'm afraid.
The rear mounting bracket bolts to the ends of the frame extensions where the light is attached. Front ones go on the top shock mounts.
navtrad
#5 PostAuthor: navtrad » Sat Feb 17, 2018 9:46 am
Thanks Al. PM sent.
Regards,
Nigel
#6 PostAuthor: Al » Sat Feb 17, 2018 10:17 am
PM replied to Nigel.
#7 PostAuthor: Al » Sat Feb 17, 2018 11:42 am
99.9% sure it wont fit with the existing grab rail see attached.
navtrad
#8 PostAuthor: navtrad » Sat Feb 17, 2018 11:48 am
Yep, I think you are right Al.
navtrad
#9 PostAuthor: navtrad » Sat Feb 17, 2018 12:24 pm
Just a last question to anyone who might know;
Did Kawasaki make a specific rack for the J?
Before I take up Al’s kind offer, if there is such a thing as an OE Kawasaki rack - does anyone have one they would be willing to part with?
Regards,
Nigel
tlc
#10 PostAuthor: tlc » Sun Feb 18, 2018 6:15 am
I spent a long time trying to find a dedicated rack.
The only one I ever found was the Rickman which is not for sale.
navtrad
#11 PostAuthor: navtrad » Sun Feb 18, 2018 8:31 am
Thanks, that's useful information.
Looks like the grab rail is not fitted in the picture. Is that because it wont fit with the Rickman or did you choose not to fit it?
Regards,
Nigel
tlc
#12 PostAuthor: tlc » Sun Feb 18, 2018 4:23 pm
The thing with the J is that support for any rail or rack has to go through the lock bolts. Therefore to fit one you have to remove the other. The instructions actually state it is necessary to chop the helmet/seat lock to make it fit. I managed to do so without doing this by using another lock as I still have one key for All locks.
The next point of connection for the rack is under the tail at the end of the frame rails. These use a dropper bracket to make a third point of fixture.
All in all a good strong fix but like Al says don’t overload the rack.
Bearing in mind the reduced frame thickness compared to earlier Zeds it is also advisable to watch the weight on any rack.
navtrad
#13 PostAuthor: navtrad » Sun Feb 18, 2018 7:43 pm
Hmmm. That’s very interesting and thanks for the info.
I probably wasn’t thinking of putting too much weight on there. Just a small top box with a back pad occasionally for when my wife wants to go out on the bike with me as nowadays she feels more secure like that.
But I’m certainly going to be wary of putting too much weight on it now.
Nice looking bike, and the Rickman looks good on it too.
Regards,
Nigel
