side stand bracket
side stand bracket
Bit of a longshot be here goes in the hope that someobne may have a wrecked frame out there, i am after a sidestand bracket this is the part that is welded to the frame (hence the frame would be duff) i am also need the seat brackets (again the ones on the frame)...... a longshot but shy bains get no sweets
GPZ1100 A1 zrx1100 gsa1200
Re: side stand bracket
I am not sure the suverners wll understand "bain"
Try John Browse at Wrexham.
I can get a Doremi side stand bracket for you if you are desperate but they are not cheap. PM me if you get stuck.
The think I have a bracket in a box of old tat in the shed, give me a chance to go look and if I can find it, I will send you a photo to see if it's what you need.
Brilliant. Thaks
Thanks that brilliant
Ratty wrote:The think I have a bracket in a box of old tat in the shed, give me a chance to go look and if I can find it, I will send you a photo to see if it's what you need.
would these Brackets help ?
they were welded on to a Z1R frame so it could have a Z1000 body work and seat fitted, its being turned back to Z1R body work so they will have to come off
the only down side is the Bike is out at my place in Germany right now so its going to be a little while before I will be out there to pick it up
let me know if your think they will be of help
sorry for the poor pic
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
along with some lesser makes
Z1300 A1,
KE175b, KE175F
brilliant thank you Hartyb have sent pm.
If you have any of the other bits Ratty would much appreciate
Will this help?
Yes that’s exactly what I am looking for I will drop you a pm. What a fantastic site and a fantastic bunch of guys
Hi deka,
If it's any use to you it's yours if you are a PUM so if you haven't already here's a good excuse to join.
Send me your address and I will get it in the post to you.
Regards,
Nigel
Regards,
Nigel
I have the seat rail section of frame in my shed with seat brackets attached if it's any help. It might be easier for you to have the brackets still attached so you can measure or jig it up before you cut them off? Let me know if you want it. I can take photos at the weekend if needed. Mick
while we have the attention of the parts of Frames stockists
has any one got the back part the bit the rear light mounts to of a Z1R or ST or Mk2 frame may even be the same on a LTD and J but not sure
this is the part I would like to find
Z1300 A1,
KE175b, KE175F
Z1300 A1,
KE175b, KE175F
Parcelled up and posted first class, let me know when it arrives.
Hope it helps out.
Nigel
Hope it helps out.
Nigel
Ratty wrote:Parcelled up and posted first class, let me know when it arrives.
Hope it helps out.
Nigel
Thank you Nigel
deka wrote:Ratty wrote:Parcelled up and posted first class, let me know when it arrives.
Hope it helps out.
Nigel
Thank you Nigel
Will do
Users browsing this forum: No registered users and 145 guests
