28mm Z1R Carbs
28mm Z1R Carbs
Would anyone have a set of 28mm Z1R carbs that they might like to sell? Or know of where I might get a set?
Re: 28mm Z1R Carbs
Hi Scott
if you don't find Z1R carbs, you could use the carbs of a Z1000ST, they're practically the same, you only have to blank the hole on the third carb where the vacuum pipe for the fuel tap comes . They're easier to find and mostly cheaper.
My Z1R has ST carbs on and it performs very good!
Good luck!
Good luck!
Re: 28mm Z1R Carbs
Thanks Phillipe, I’ll certainly bear that in mind!!!
Steve Cooke
- ZedHead
Re: 28mm Z1R Carbs
scott wrote:Would anyone have a set of 28mm Z1R carbs that they might like to sell? Or know of where I might get a set?
Might have!
Users browsing this forum: No registered users and 73 guests
