1976 kz or z900 frame parts
Nick.s
#1 PostAuthor: Nick.s » Fri Nov 09, 2018 4:19 pm
I’m looking for a rear near side indicator bracket, mine is bent and because it’s double skin I’m having trouble straightening it.I was hoping someone had a scrap frame they could cut one off.
Please pm me if you have
Nick.
8 Valve Mark
Re: 1976 kz or z990 frame parts
#2 PostAuthor: 8 Valve Mark » Fri Nov 09, 2018 8:05 pm
try looking for a kh,100/125, z200, 250,400 etc frame as the indicator mounts are so similar they're probably the same dimensions.or the easiest, cheapest option:get a good local metal worker/welder to remove, straighten and re-install your existing mounts.bosh! easy :) m ps scrap 900 frames no longer exist as far as i know. good luck though
Mick J
#3 PostAuthor: Mick J » Sat Nov 10, 2018 10:11 am
Hi Guys, I have some frame parts currently on ebay from a front end damaged frame. I also have another rear frame section that I could sell if required, which has the rear brackets you want. Cheers, Mick
Nick.s
#4 PostAuthor: Nick.s » Tue Nov 13, 2018 6:56 pm
Hi mick, it’s actually the offside bracket I need I was looking at it with the frame upside down :lol:
How much would you want for your bracket?
Nick.
