oil cooler take off
rsullivan
oil cooler take off
#1 PostAuthor: rsullivan » Fri Nov 30, 2018 10:29 am
looking to buy the take off connectors to fit a oil cooler to my 77 Z1000 A1. also a dresda swing arm or something similar
scott
Junior Section leader
Re: oil cooler take off
#2 PostAuthor: scott » Fri Nov 30, 2018 11:58 am
I’m sure I managed to get those takeoffs from Earls but they are about £100, if I remember rightly. The adapters I got from Earls but the connections and hoses I got from “Torques”.
rsullivan
#3 PostAuthor: rsullivan » Fri Nov 30, 2018 12:30 pm
will give earls a try thanks.
#4 PostAuthor: chrisu » Fri Nov 30, 2018 1:47 pm
try z1enterprises.com. I bought from there and they were much cheaper. Was a while ago now though.
rsullivan
#5 PostAuthor: rsullivan » Fri Nov 30, 2018 4:28 pm
will give them try thanks
#6 PostAuthor: Pigford » Sat Dec 01, 2018 9:03 am
I got a set you can have for some beer tokens - PM sent
The Living Zed
#7 PostAuthor: The Living Zed » Wed Dec 05, 2018 9:16 pm
I need an oil cooler too, but not sure what size it should be
or how to plumb em in
#8 PostAuthor: paul doran » Wed Dec 05, 2018 10:08 pm
I have a cooler complete with pipes and fittings
The Living Zed
#9 PostAuthor: The Living Zed » Wed Dec 05, 2018 11:01 pm
How much you want. Can you send me pictures please
scott
#10 PostAuthor: scott » Thu Dec 06, 2018 11:13 am
10 row oil coolers about 240mm long, 70mm high are to be found on ebay for about £40
I use these ones:
https://www.ebay.co.uk/itm/NEW-OIL-COOL ... rk:35:pf:0
#11 PostAuthor: Ultim8pc » Thu Dec 06, 2018 1:33 pm
http://www.ebaystores.co.uk/AlloyFuelTank
Try these guys, they have coolers. brackets, connectors and pipes.
#12 PostAuthor: paul doran » Thu Dec 06, 2018 1:49 pm
The Living Zed wrote:How much you want. Can you send me pictures please
pictures later tonight
The Living Zed
#13 PostAuthor: The Living Zed » Thu Dec 06, 2018 7:50 pm
That's sound Guys. Many thanks.
