Starter Gear Z1000 A1
HighlandStu
- Regular Poster
I'm looking for a starter gear with needle bearing and rubber damper, its the early type with what looks like a 22mm bearing ID - ideally just the bearing and damper but can't buy these anywhere.
Re: Starter Gear Z1000 A1
May be able to help you there Stu, will look tomorrow the damper comes in three sizes though, i know i have a starter gear and damper not sure on the bearing which can be bought elsewhere.
http://www.z-power.co.uk/bearing-starter-clutch
http://www.z-power.co.uk/bearing-second ... ch-z650750
HighlandStu
- Regular Poster
Nice one thanks
You have a P.M
