Z900 A4/Z1000a1/2 PARTS
Cleggy
#1 PostAuthor: Cleggy » Wed Nov 13, 2019 11:13 am
Hi all,
I need a few bits for the latest build.
Looking for a
Front wheel axle complete for Z900 A4/Z1000 series, preferably with speedo drive.
4 X lower crank case flange bolts (8x95mm I think)
Starter motor
Cam chain tensioner gear. The full lot if possible.
Many thanks
Cleggy
Z1000 A2
Z900 A4
Z1 Pineapple Replica
z1b 900
KH250B
DT250E
DUCATI 748 BIP
TRIUPMPH DAYTONA 955
TRIUMPH SPEEDY 1050
TRIUMPH BONNIE T120R
BSA SPITFIRE REPLICA
TRITON T110
Re: Z900 A4/Z1000a1/2 PARTS
#2 PostAuthor: paul doran » Wed Nov 13, 2019 3:25 pm
I should have all of the above
Are the four bolts the ones inside the crankcase
Cleggy
#3 PostAuthor: Cleggy » Wed Nov 13, 2019 7:38 pm
Paul,
Thank you. No they are the external ones, two at each end of the crank.
I removed mine for plating and God knows where I put them.
Please PM me and thank you again for your help.
Cleggy
Z1000 A2
Z900 A4
z1b 900
KH250B
DT250E
DUCATI 748 BIP
TRIUMPH SPEEDY 1050
TRITON T110
