Fuel Tap Black 73 Brass Fitting
IrishKev
#1 PostAuthor: IrishKev » Sat Nov 23, 2019 5:36 pm
Moved to bike help
Re: Fuel Tap Black 73 Brass Fitting
#2 PostAuthor: ADRIAN H » Sat Nov 23, 2019 7:29 pm
Maybe a silly idea. But what about soldering the crack insitu ?
#3 PostAuthor: kev edwards » Sun Nov 24, 2019 9:24 am
Heat the tap up after stripping it down, the brass will pull out, make or buy pipe of correct size, warm up tap freeze pipe and push pipe in
KeithZ1R
#4 PostAuthor: KeithZ1R » Sun Nov 24, 2019 9:43 am
I have successfully soldered carb overflow tubes in the past, cleanliness is the key and a pen torch, see no reason why should not work there.
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
mick.harris
#5 PostAuthor: mick.harris » Sun Nov 24, 2019 9:48 am
I've a spare if it helps you out, I've sent you a P.M.
#6 PostAuthor: Ultim8pc » Sun Nov 24, 2019 10:33 am
I had the same issue.
I fixed it by pushing another piece of brass pipe over the damaged one.
IrishKev
#7 PostAuthor: IrishKev » Sun Nov 24, 2019 2:48 pm
Hi Guys
Thanks for getting back to me, I will try the ideas you have and see how I get on.
I am not great at soldering, do you know where I might get a same size length of brass pipe.
Regards Irishkev
Keefleaf
#8 PostAuthor: Keefleaf » Sun Nov 24, 2019 3:03 pm
Available on EBay,- brass tube 2mm - 7mm
Seller - maccmodels
