Z1000A1 OEM Exhaust hanger brackets.
Ratty
Re: Z1000A1 OEM Exhaust hanger brackets.
#16 PostAuthor: Ratty » Sat Nov 30, 2019 6:08 pm
King of Kings wrote:Pretty sure I’ve got my old pair of the OE brackets somewhere :(
If you do happen across them I would love to borrow (Or buy) them from you.
Thanks,
Nigel
#17 PostAuthor: r3sc » Sun Dec 01, 2019 8:34 am
Good Morning All,
I would like to thank everyone who has given input into this topic and especially Ratty who offered to manufacture some hangers.
Sadly, and by my own admission I fall into the “Rivet Counter” category and although my new replica exhausts won’t be OEM I would like to get as near as possible by using the standard mounting brackets, hence my original post to ask if anyone had a pair that they would like to sell me.
With this in mind, if anyone out there has any please PM me!
I’ve had much experience of Z’s but I am by no means an expert on originality.
I would really like to get my bike back to the condition it was when it rolled off the production line in 1977 and that’s where you guys come in. As my peers in this matter I hope in the future I can post images of it and receive your knowledgable guidance on what’s right and what’s wrong.
Hopefully, that day won’t be too far away.
Anyway, if anyone does have a pair of OEM hangers for sale, please let me know.
Best Regards.
#18 PostAuthor: Philippe » Sun Dec 01, 2019 8:53 am
Hi Nigel
as promised, pictures and measurements from the exhaust hangers.
The dimensions are in millimeters and are "more or less" correct...
The thickness of the steel plate is 2.25 mm
Both of the hangers have on the upper inside a rectangular cage where an M10 self locking nut with fine thread (1,25) is catched. The nut can slide in order to adjust the exhaust.
The right hand hanger is a mirror view of the left hand one, except that the left one has an extention for the rubber damper acting as a stopper for the main stand.
The cross section of the hangers is U shaped.
the two hangers
The outside view of the two hangers
the "cage" for the M10 nut
The cage on the inside where the M10 locknut is catched, it can slide, on the outside of the hanger the upper hole is not round but more or less oval shaped
the side view of the right hand hanger
A frontal side view of the right hand hanger to see the shape of the bend
the side view of the left hand hanger
A rear sight of the left hand hanger
the dimensions of the right hand hanger
The measurements/dimensions of the right hand hanger,the left one has the same dimensions except for the extention
the dimensions of the left hand hanger
The dimensions of the extention on the left hand hanger
top view of the extention of the left hanger
A top view of the extention of the left hanger
I hope you can do something with the pictures...
I made two exhaust hangers for my MK2 out of a steel plate.
The best thing to do is make an example out of cardboard to make sure they fit, then you can flatten the cardboard on the steel plate and draw it over . Remember the hangers aren't straight, they're bent to the inside.
Good luck!
#19 PostAuthor: Ultim8pc » Sun Dec 01, 2019 12:14 pm
Philippe wrote:Hi Nigel
Thanks for your help as ever Philippe!
If anyone think they can fab something decent for those who need them, then please let us know.
Please bear in mind that longer term I am working to get accurate copies manufactured.
Ratty
#20 PostAuthor: Ratty » Sun Dec 01, 2019 6:28 pm
Thanks Philippe, I am still hopeful that someone will come up with a pair to copy. However the drawing and photos should allow me to cobble something together that will look quite authentic, from 500 yards!
Regards,
Nigel
#21 PostAuthor: r3sc » Fri Dec 13, 2019 6:14 pm
I’m now only looking for a left hand mounting bracket as I’ve managed to find a right hand.
Can anyone help?
johno
#22 PostAuthor: johno » Sun Apr 16, 2023 7:01 pm
Hi
Di anyone manage to manufacture the hangers for or Busso exhaust systems? Getting desperate to fit this system. :D
#23 PostAuthor: Z1streetfighter71 » Sun Apr 16, 2023 8:03 pm
Iv got a pair if you want them, they were rotten on my z1000 and were fairly carefully cut off, shipping will be from Ireland
if you want to cover it.
#24 PostAuthor: Z1streetfighter71 » Sun Apr 16, 2023 8:07 pm
Sorry only realized this was an old post.
johno
#25 PostAuthor: johno » Mon Apr 17, 2023 2:33 pm
Hi,
Yes please that would give me a chance!!
How do you want me to sort payment?.
Cheers John
#26 PostAuthor: Z1streetfighter71 » Mon Apr 17, 2023 2:43 pm
Hey mate, glad that they will be use to someone, iv been keeping them as i knew someone would want them at some stage. , PM me on you address and ill post them off this week in the snail mail, sure we can sort money out when i know how much the post is all ill ask is the cost of the post.
#27 PostAuthor: warren3200gt » Mon Apr 17, 2023 2:46 pm
Exhaust hangers are part 22 & 31 or did I miss something?
PUM 488 June 2023
#28 PostAuthor: r3sc » Mon Apr 17, 2023 3:00 pm
The original post was for the part numbers detailed by Warren and these allow mounting of the Busso system to the existing A1 frame mounted hangers!
I’m with Warren and I’m not sure what’s being searched for!
compo z1r
#29 PostAuthor: compo z1r » Mon Apr 17, 2023 6:53 pm
got the same question going on on FB with the z1r d3 exhaust hanger !!! with a bit of digging turns out its the same bracket as a z650/B deffo different part No's but same ?
1037 left z1r d3
d2 1038.jpg (88.61 KiB) Viewed 2613 times
650 b 1040
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2026
#30 PostAuthor: warren3200gt » Mon Apr 17, 2023 6:55 pm
Well I've got a pair of 650 ones. Not sure the offside one has the extra hole on the 650 one though. I'll have to dig em out and post a pic. Part 23 & 26
Screenshot_20230417_200026_Samsung Internet.jpg (38.6 KiB) Viewed 2607 times
PUM 488 June 2023
