1977 Z1000A1 Switchgear
#1 PostAuthor: r3sc » Sun Dec 01, 2019 8:42 am
Hi,
In my bike’s dim and distant past a previous owner decided to fit different handlebars which wouldn’t accept the wiring running through them so he cut a large scallop out of the OEM switchgear on both sides to allow the wiring to exit.
To rectify this problem I am looking for a pair of OEM bottom switchgear halves or complete units so that I can run the wires down the original handlebars which thankfully came with the bike.
If you can help, please send me a PM.
My switches work fine but ideally I just need a good pair of lower half bodies that haven’t been modified.
Many thanks.
Re: 1977 Z1000A1 Switchgear
#2 PostAuthor: warren3200gt » Sun Dec 01, 2019 1:54 pm
I would think 650 ones would be the same. So you could broaden your search with more chane of success. Although I would just fill the new scollops with plastic metal or jb weld or something. Gotta to be easier and shed loads cheaper than finding the new bits.
#3 PostAuthor: Philippe » Sun Dec 01, 2019 4:12 pm
Hi r3sc
as you mentioned in your post: a different handlebar was fitted...it happened a lot of times in the past so the original undamaged switchgear halves are difficult to find.
As Warren mentioned, you could try to find those of a Z650, you never know if you're lucky until you tried it.
8 Valve Mark
#4 PostAuthor: 8 Valve Mark » Sun Dec 01, 2019 6:50 pm
i had a pair until recently, sold the lhs to someone in need. so i still have the rhs if you need one. m
#5 PostAuthor: r3sc » Sun Dec 01, 2019 9:25 pm
Yes please.
Could you please PM me with details. It is for the A1?
Many Thanks.
