Used 73 Z1 Ducktail
wilsonsjw11
Used 73 Z1 Ducktail
As the heading says, used 73 Z1 ducktail wanted please.Not Z1A or Z1B.
Regards.
Steve.
Regards.
Steve.
Re: 73 Z1 Ducktail
wilsonsjw11
Re: 73 Z1 Ducktail
Philippe,
Thanks for the heads up but not with that graze and split on it.
Regards
Steve
Regards
Steve
wilsonsjw11
Re: 73 Z1 Ducktail
Thanks for the link but I'm after one that requires painting.
Regards
Steve.
Regards
Steve.
Re: Used 73 Z1 Ducktail
How do you know which model of Z1 it is off? I thought they were all the same up to the squarer Z900 version, someone enlighten me please
73,74,75 are the same, 74,75 decals are hard to remove, it can be done.
wilsonsjw11
73,74 and 75 are not the same.
There is a very small difference on the 73 unit hence me being specific.
Regards
Steve
Regards
Steve
Hi Steve
tell us all about the little difference, I'm curious and always ready to know more about the Z1.
wilsonsjw11
Philippe,
If you remove the document tray on a Z1 you will see 2 "rails" in the plastic moulding of the tail.Not on Z1A or Z1B or the later NOS units either.
Regards
Steve
Regards
Steve
True, they are not the same.
Hi Steve
thanks for the information, I'll check it out !
