Brake upgrade
John0622
Brake upgrade
#1 PostAuthor: John0622 » Tue Aug 18, 2020 11:55 am
Hi all, new to the forum but I have a '78 Z1000 A2, single disc model. Any advice on a decent brake upgrade whether that be a dual disc conversion you have for sale or an alternative caliper set up. Many thanks.
Jerry
President
President
Re: Brake upgrade
#2 PostAuthor: Jerry » Sun Aug 23, 2020 8:53 pm
Use Kawasaki parts, a 5/8 master cylinder, the extra calipers will be the same, might need a bit of machining on the mount plate, and a pair of matching discs, dead easy!
Jerry
President
President
Re: Brake upgrade
#3 PostAuthor: Jerry » Sun Aug 23, 2020 8:55 pm
Single disc set up uses a thicker disc than the twins, so you need a pair of thinner ones.
KWACKERZ1
Re: Brake upgrade
#4 PostAuthor: KWACKERZ1 » Tue Sep 01, 2020 12:03 pm
If you use a Harrison billet caliper you can bolt one straight on, I use them on mine.
http://www.billet.co.uk/index2.html?home.html~mainFrame
John0622
Re: Brake upgrade
#5 PostAuthor: John0622 » Tue Sep 01, 2020 7:23 pm
Bought the Harrison, lovely bit of work, having it fitted at the end of the month along with braided brake lines.
Tonka
Re: Brake upgrade
#6 PostAuthor: Tonka » Tue Sep 01, 2020 7:48 pm
First job is to fit a twin disc master cylinder and see how that goes.
Done this on a number of Z1's and it definitely improves the braking.
That's on the understanding that the brake flexi pipes are not 30 years old!
Inheritance? What inheritance? He spent it all on booze, women and Zed parts!
Users browsing this forum: Stugill and 49 guests
