Fuel level sensor
JimBoUK
Fuel level sensor
#1 PostAuthor: JimBoUK » Mon Sep 06, 2021 1:39 pm
Hi,
I’m after a fuel level sensor.
The bike is a GPZ1100B1 but it’s converted to carbs. The tank I’ve got for it was on a Z1100R so has a petrol tap and the fuel sensor is different. It might be the same sensor as a GPZ B2 and maybe even a Z1000J.
It’s the sensor with 6 mounting holes not 5.
I’ll also ideally need the plastic cover for it as well.
The part number for the sensor might be 52005-1026
If anyone has one they would sell please let me know as Kawasaki don’t have them and I can’t find one anywhere
Re: Fuel level sensor
#2 PostAuthor: Al » Mon Sep 06, 2021 3:20 pm
Looks like the plastic cover is available even if the gauge is not. Normally they just fall off so unlikely to find one if you do get the sender / sensor. :(
14025 140241434
The gauge unit for the six bolt version appears to be 520051061
https://www.cmsnl.com/kawasaki-z1100r1- ... TYxLZ1KiUk
The 'fits these models' list shows up some years of GT550 so perhaps this one.??
https://www.ebay.co.uk/itm/304103440311 ... SwTgJhFNDS
JimBoUK
#3 PostAuthor: JimBoUK » Mon Sep 06, 2021 5:45 pm
I’ve found this from CMS.
https://www.cmsnl.com/products/gauge-fuel_520051026/
Has anyone used CMS before ?
Robw
#4 PostAuthor: Robw » Mon Sep 06, 2021 9:40 pm
I have used them a couple of times in the past. Postage has always been expensive, probably more so now. However they are pretty good to get spares off, albeit as a last option.
I bought the oval plastic cover for my B1 last year and got it from Cradley heath Kawasaki.
Rob
Mr Bump
#5 PostAuthor: Mr Bump » Tue Sep 07, 2021 6:44 am
JimBoUK wrote:I’ve found this from CMS.
Yes, quite a lot. As the man says, the postage isn't cheap (it gets more reasonable the more you buy, if that makes sense) and the stuff can take a while to arrive but they are very reliable and prices tend to be fairly competitive. They often have a bit that you cannot find elsewhere, especially for Yamaha. Recommended.
Olly
Lemmy
JimBoUK
#6 PostAuthor: JimBoUK » Tue Sep 07, 2021 12:54 pm
Thanks guys.
I’ve ordered one from CMS
