Z900 rear wheel or Hub (Drum Brakes)
Dero
#1 PostAuthor: Dero » Sun Feb 18, 2024 1:42 pm
I am looking for a rear wheel Drum for a 1976 Z900 a4
If you have one for sale please let me know.
I wanted to fit Sisc rear but am told it won’t fit.
Re: Z900 rear wheel or Hub (Drum Brakes)
#2 PostAuthor: ADRIAN H » Sun Feb 18, 2024 8:06 pm
Can’t see why it wouldn’t fit. But it’s not the correct rear brake for a Z900A4 Drum brake is correct fitment. I prefer the drum brake, as the standard disc drake is pretty much useless.
Have you got the correct swing-arm.
Torque Arm connection bracket for Disc brake is on the top of Swing-arm. Drum has torque arm connection bracket on the underside.
Sorry haven’t got a spare hub. Good luck
Dero
#3 PostAuthor: Dero » Mon Feb 19, 2024 5:52 pm
Thanks Adrian, I hope to get a hub soon, I’ve bought a front hub which I’ll have respoked, I only need the rear hub or wheel now.
I really don’t like the alloy wheels, I don’t think they do the bike any justice.
I was leaving my options open on the rear as a wire wheel with disc is better than the alloy wheel.
gray
#4 PostAuthor: gray » Fri Feb 23, 2024 6:29 pm
pm sent
gray
Andy M
#5 PostAuthor: Andy M » Mon Feb 26, 2024 6:23 pm
Did you get sorted ?
kwaker nacker
#6 PostAuthor: kwaker nacker » Thu Feb 29, 2024 7:39 pm
got a pair of akront wheels sat in my garage twin disc on the front and drum rear of my a4 .
nice to be back in the z1 owners club once again
#7 PostAuthor: chrisNI » Fri Mar 01, 2024 5:57 pm
Is this sorted? I may have come across a Z1B one (to be confirmed by further research)
Andy M
#8 PostAuthor: Andy M » Fri Mar 01, 2024 6:08 pm
chrisNI wrote:Is this sorted? I may have come across a Z1B one (to be confirmed by further research)
Same reason I asked above I have got a Z1b one too.
#9 PostAuthor: Z1streetfighter71 » Fri Mar 01, 2024 7:23 pm
Im looking for a 303 5D or close to it. :D
Dero
#10 PostAuthor: Dero » Mon Apr 08, 2024 1:53 pm
Thank you to those that helped me get a rear wheel.
ALL SORTED now thank you.
Regards Derrick
