Z1r rear frame
Re: Z1r rear frame
Yes you’re correct the front seat mounts and the left hand pillion peg mount
Re: Z1r rear frame
Hey compo is that your red frame
- Z1streetfighter71
- ZedHead
Re: Z1r rear frame
Tony wrote:Yes you’re correct the front seat mounts and the left hand pillion peg mount
I’m in the same boat, I’m missing seat brackets, turn signal ears and the seat latch on one of my frames along with the light bracket. I figured all of those things were unobtainable so I drew my own. This is currently being cut right now. I’ve decided to try and make my own light bracket. Still doing the drawing for that one.
Re: Z1r rear frame
Hi street fighter keep us posted how things turn out looks like it will be a big job cheers tony
Re: Z1r rear frame
Z1streetfighter71 wrote:Tony wrote:Yes you’re correct the front seat mounts and the left hand pillion peg mount
Light bracket ? Rear ?
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Re: Z1r rear frame
U want one of these as original u will have to extend indicator stem or renew easy or use as is tail tidy ?
https://www.ebay.co.uk/itm/396474629503 ... media=COPY
- Z1streetfighter71
- ZedHead
Re: Z1r rear frame
compo z1r wrote:Z1streetfighter71 wrote:Tony wrote:Yes you’re correct the front seat mounts and the left hand pillion peg mount
Yea mate same as tony but not missing as much. , i have one frame from the indicators back missing but void of any brackets or mounts and another frame missing the seat latch and mounts. ill fabricate most of it as im fairly good with the fiddly bits as i used to design and build tattoo machines for many a year.
Re: Z1r rear frame
- Z1streetfighter71
- ZedHead
Re: Z1r rear frame
compo z1r wrote::D The z250 has the same light bracket as a z1r but with indicator stalks 24mm a side shorter a lot fitted them back in the day to tidy up back end easy to fix 2 welds ground off and replace tube with one 48mm longer easy done
I read that about the Z250 light unit, handy in a pinch. Both me and Tony are missing the bracket on the frame, as below.
Re: Z1r rear frame
that's part of frame and do's not have a part No though a chap on ebay makes them and toon at the z1r owners register has made one or 2 so can b bought !! make sure the mounts for the cover is correct or the seat lock opening in the cover don't line up with the lock seen it happen ok
