Hi, I need all the parts in the title. My engine had all of these removed before I bought it, so I need all parts to make the starter able to turn the engine (I have a starter motor).
Thank you
Scott
Z1000a1 starter clutch, drive gear and idler sprocket
scott reid
Re: Z1000a1 starter clutch, drive gear and idler sprocket
hi there, this was off my a2, think they were new rollers, £35.00 posted if any good for you
ken
ken
scott reid
Hi Ken, yes please. I've sent you a PM
Scott
Scott
Hi Scott
Pretty sure I’ve got an idler gear somewhere
will check when I’m home
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Hi Scott, not received any pm, got a aftermarket alternator gasket from Zpower available if you haven't already got one, £4.00
scott reid
I'm still needing parts. I have the part that the 3 rollers and springs are housed in, but I still need the gear that fits onto that has the case hardened surface for the rollers to grip, and also need the washer that goes between the roller housing and the large gear.
Ta.
Ta.
Got one but I'm not sure if its Z1000 or Z1000J....
Anyone know if they're the same?
21167-003
seems not
seems not
Keith
mistaken.
mistaken.
