Hi Guys.
I have a UK Z1R frame and V5 in my name but previous owner/s cut the back end off.
Looking for a Z1R, Z1000D frame or rear section.
I need the rear section to include lock mount.
Damaged, rotten, no numbers or V5 considered.
Cheers.
Gus
Wanted Z1R Z1000D frame or rear section
"Set the GRINDER on it"
Re: Wanted Z1R Z1000D frame or rear section
Theres been a frame on marketplace for a while , not sure if you may have seen it , its a bit ropey
https://www.facebook.com/marketplace/it ... _code=null
Thanks for that I'll keep an eye on it.
Much appreciated.
Much appreciated.
neilbarrett
- ZedHead
Have you a pic of the part you want as I've a frame I want rid of
Thanks Neil.
I'll try and get photos in the morning.
Much appreciated.
Gus
Much appreciated.
Gus
neilbarrett wrote:Have you a pic of the part you want as I've a frame I want rid of
Apologies Neil.
My frame is at a friends workshop and he died a couple of weeks ago.
As of yet I don't have access to get my stuff back at the moment.
Cheers.
Gus.
i have neil he requires back end ? from indicator plates back
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
compo z1r wrote:neilbarrett wrote:Have you a pic of the part you want as I've a frame I want rid of
Cheers Compo.
Hope you are well my friend.
Much appreciated.
Gus
