Dyna Green Coils
bigmac103
Dyna Green Coils
#1 PostAuthor: bigmac103 » Fri Jun 26, 2009 6:26 pm
Where's the best place to get these DC1-1 (3 Ohm-green)? or is there an alternative?
Lost in the desert somewhere
#2 PostAuthor: Pigford » Fri Jun 26, 2009 6:33 pm
Green or Grey (2.2 ohms) OK... Ebay for a bargain.... :wink:
bigmac103
#3 PostAuthor: bigmac103 » Fri Jun 26, 2009 7:33 pm
tried ebay for the green 3 ohms no joy, what are the grey ones? can I use them with the Dyna S points?
#4 PostAuthor: Pigford » Fri Jun 26, 2009 7:42 pm
bigmac103 wrote:tried ebay for the green 3 ohms no joy, what are the grey ones? can I use them with the Dyna S points?
DYNA S - Points..... a contradiction in terms :!:
Yes, 2.2 or 3.0 ohms are OK with Dyna S.... Make sure you only use proper leads.... DYNA leads are best coz they are designed to work with the whole DYNA set up... SOme lead/plug caps can cause problems... :??
bigmac103
#5 PostAuthor: bigmac103 » Fri Jun 26, 2009 7:49 pm
What would you use Pigford, Grey or Green? The points system are the Dyna S and the coils have been "anything that was lying around at the time!" I need to sort this out so any help would be greatly appreciated.
#6 PostAuthor: Pigford » Fri Jun 26, 2009 7:57 pm
I'd go for the 3.o with DYNA S.... (2.2 for Dyna 2000)...
Either will do, gives you more choice when hunts a pair down... Don't "mix & match" though :!:
bigmac103
#7 PostAuthor: bigmac103 » Fri Jun 26, 2009 8:04 pm
Thanks P. I'll hunt the Green ones! :up
bigmac103
#8 PostAuthor: bigmac103 » Fri Jun 26, 2009 8:17 pm
Can I use any pair of coils with the S points system? just until I get the green meanies?
#9 PostAuthor: Pigford » Fri Jun 26, 2009 8:20 pm
bigmac103
#10 PostAuthor: bigmac103 » Fri Jun 26, 2009 8:26 pm
Very helpful, thanks Mr P.
