WANTED Z1000J GPZ1100B1 CENTRE STAND
I am looking to buy a centre stand for a GPZ1100B1 I assume a Z1000J one will fit but would love to have this confirmed if anyone knows.
- firyembers
- Custard Creem
if you can confirm the gpz 1100 unitrack is the same then i will send you for the cost of postage.
Its a littly tatty and do not use it,since i the lugs are missing off my frame..
Life shouldn't be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, cigar in one hand, beer in the other, body used up, totally worn-out and screaming, "WOO HOO, what a ride!"
- firyembers
- Custard Creem
This the part number for unitrack 34011-1078 and fits zx1100 a1-a3
one here is that your model...
http://www.ebay.co.uk/itm/1981-Kawasaki ... 53e43dcdf1
Actually there is a few about so you should not have any bother getting one..
Its likely they are pretty standard and differ only by the part number.
If you like or do not find one measure up the shoulder bolt diameter,the connecting legs centre to centre and will let you know when i get back home in September (17th)
- Ginger Bear
- firyembers
- Custard Creem
According to my Zedder program its on 10 models
If that helps
If that helps
- Ginger Bear
- firyembers
- Custard Creem
If that helps
If that helps
