front sprocket
brian 450
front sprocket
#1 PostAuthor: brian 450 » Fri Aug 19, 2011 8:18 pm
I am after a 19 tooth front sprocket for my Z if any one has one kicking about. If not i will have to go to talon.
DDZ900
sprocket
#2 PostAuthor: DDZ900 » Fri Aug 19, 2011 8:55 pm
530 or 630 ??? i have loads i will look :wink:
brian 450
#3 PostAuthor: brian 450 » Sat Aug 20, 2011 7:51 am
Sorry forgot to put I need a offset one.
#4 PostAuthor: Ginger Bear » Sat Aug 20, 2011 9:36 am
Brian, I'd be amazed if you found one on here, since they are 'special order' in the first place.
In my opinion, it is the way to go when running 17" wheels on an early Zed.
Best thing to do is go straight to Talon. Tell them you want a 5/8" offset, the same as they do for Debben..... That way there should be no confusion, & believe me, I have a mega offset sprocket to prove that things get confused, even with the clearest instructions. :roll: Talon did remake it FOC though.
Cost will be around £60, but will get a little cheaper, the more you order.
#5 PostAuthor: Pigford » Sat Aug 20, 2011 10:25 am
Brian, if you're going for a 5/8" off-set + 19T, I wouldn't mind one, so if you can get discount place the oreder & I can collect them & post to you :wink:
Let me know what you think 07970 958411
garyd
#6 PostAuthor: garyd » Sat Aug 27, 2011 10:05 pm
Did anyone order these...and if not should we...'coz I'm in the market for one.
garyd
#7 PostAuthor: garyd » Mon Aug 29, 2011 7:49 pm
Ps, they are on the Debben site for £55
And from the states...
http://www.americanclassix.com/streetfi ... sions.html
$84.50...what ever that is in enslish...pretty much the same...but I'd guess you'd get hit for VAT on that.
and std gpz750
http://www.jtsprockets.com/52.0.html?&L ... id=1140&p=
#8 PostAuthor: Ginger Bear » Mon Aug 29, 2011 8:00 pm
They are only 18t though... :cry:
garyd
#9 PostAuthor: garyd » Wed Aug 31, 2011 12:37 pm
So, the bug question is...did any get ordered from Talon or are you waiting for enough people to make up an order?
Gary
#10 PostAuthor: Ginger Bear » Wed Aug 31, 2011 12:56 pm
Gary,
I'd contact Pigford who I would guess is still in the market for one of these. Brian 450 has posted elsewhere on here that he may sell his Z1000, so his need may have gone. :??
garyd
#11 PostAuthor: garyd » Wed Aug 31, 2011 8:25 pm
:up Cheers...will do
