front sprocket
front sprocket
I am after a 19 tooth front sprocket for my Z if any one has one kicking about. If not i will have to go to talon.
Brian, I'd be amazed if you found one on here, since they are 'special order' in the first place.
In my opinion, it is the way to go when running 17" wheels on an early Zed.
Best thing to do is go straight to Talon. Tell them you want a 5/8" offset, the same as they do for Debben..... That way there should be no confusion, & believe me, I have a mega offset sprocket to prove that things get confused, even with the clearest instructions. Talon did remake it FOC though.
Cost will be around £60, but will get a little cheaper, the more you order.
Ps, they are on the Debben site for £55
And from the states...
http://www.americanclassix.com/streetfi ... sions.html
$84.50...what ever that is in enslish...pretty much the same...but I'd guess you'd get hit for VAT on that.
and std gpz750
http://www.jtsprockets.com/52.0.html?&L ... id=1140&p=
and std gpz750
