Z1R valves
z1rtc
Z1R valves
#1 PostAuthor: z1rtc » Wed Nov 07, 2012 1:49 am
Just took the head off my TC to check the bores etc (all great) and change the valve stem seals that Big Fluff sent over - cheers Will - but we've found that most of the valves are very slightly errr, bent! :(
Please let me know if you've got a set of straight ones that need a good home :up
Keefleaf
#2 PostAuthor: Keefleaf » Wed Nov 07, 2012 3:12 pm
PM Buzzard.
jimmock
#3 PostAuthor: jimmock » Wed Nov 07, 2012 4:32 pm
You can straighten them in the vice.
I've done it loads of times.
Jimmock. :wnkr
I hate people I don't like !
z1rtc
#4 PostAuthor: z1rtc » Wed Nov 07, 2012 7:00 pm
Keefleaf wrote:PM Buzzard.
Cheers Keith - will do
jimmock wrote:You can straighten them in the vice.
:shock: Ta jimmock, I'll keep that option in reserve :)
jimmock
#5 PostAuthor: jimmock » Thu Nov 08, 2012 12:00 am
I've done it many a time.
NEVER got one running again after this repair, obviously bad fuel??
Jimmock. :wnkr
#6 PostAuthor: Ginger Bear » Thu Nov 08, 2012 7:04 am
Z-Power do pattern valves at a reasonable price. I and a few others have used them without any problem.
hillbilly
#7 PostAuthor: hillbilly » Thu Nov 08, 2012 8:01 am
I have said before on here that the valves from a 4.2toyota landcruiser diesel.will fit with a bit of fettling.at about £8 each.its a lot of expence spared.seeing as zed ones are probly £40each.
z1rtc
#8 PostAuthor: z1rtc » Sat Nov 10, 2012 2:36 am
Ginger Bear wrote:Z-Power do pattern valves at a reasonable price. I and a few others have used them without any problem.
hillbilly wrote:I have said before on here that the valves from a 4.2toyota landcruiser diesel.will fit with a bit of fettling.at about £8 each.its a lot of expence spared.seeing as zed ones are probly £40each.
Thanks guys, but looks like my mate has already sorted it! Not sure if he was going to keep it a secret, but hopefully I'll have a head full of straight valves very soon :)
