z1100r vesrah complete gasket set
nakasaki
#1 PostAuthor: nakasaki » Wed Nov 27, 2013 9:20 pm
hi can any one suggest where i can buy a complete gasket set made by vesrah for z1100r,if these are like hens teeth which make of gaskets are good quality for a full engine rebuild thanks richy..
Gus
#2 PostAuthor: Gus » Wed Nov 27, 2013 10:24 pm
Hi Richy.
Shouldn't a GPZ1100 unitrac set be the same.
There's a few makes on ebay
Gus
"Set the GRINDER on it"
#3 PostAuthor: z1bman » Wed Nov 27, 2013 10:43 pm
no apparently there are 3 different head gaskets for the 1100 models don't know why but they have different part no's you would probably be wise to use genuine gaskets. i would suggest z1 enterprises but the z1100r is not listed on their site
Gus
#4 PostAuthor: Gus » Wed Nov 27, 2013 10:51 pm
Is that 3 different head gaskets between the A1 to A3?
Gus
#5 PostAuthor: z1bman » Wed Nov 27, 2013 11:09 pm
no between z1100 a / b / r models
Gus
#6 PostAuthor: Gus » Thu Nov 28, 2013 8:27 am
Cross referencing between sites I found this.
Head gaskets
CMSNL: Z1100R 1984 part number 11004-1119
Kawasaki.com search says that part fits these models
ZX1100-A1 (GPz) (1983)
ZX1100-A2 (GPz) (1984)
Gus
nakasaki
#7 PostAuthor: nakasaki » Thu Nov 28, 2013 10:00 am
thanks for the replies there seems to be a lot of different head gaskets accross the 1100 range think i going to to buy a complete gasket set either athena or one called gold wing,but i think genuine kawasaki head gaskets are the way forward cheers richy..
#8 PostAuthor: Ginger Bear » Thu Nov 28, 2013 5:04 pm
You could do a lot worse than a COMETIC head gasket.
