A few little bits people will have laying around
zpower
#1 PostAuthor: zpower » Thu Dec 12, 2013 2:25 am
Ok these are little bits and bobs that are bugging me and whilst not looking like much on their own some of them only come in sets and postage is stupid and ofter more than the cost of the part when a second class postage stamp would cover it.
Has anyone got:
1x Side stand spring GPZ 1100 A1/2 but anything will do - Sorted
2x Z1 oval rear light lens screws
1x carb top screw Z1000 miki's - Sorted
LH and RH switches Z1 / 900 / 1000 with throttle doesn't really matter which model - LH sorted Thanks Redbeard Still RH required.
1x Broken set of clocks as I only want the tops with glass if possible so I can build some other clocks inside them
1x Z1 / 900 / 1000 bottom cam chain guide roller rubber (the bigger thicker one)
1x Manual cam chain tensioner (New APE from the USA £32 and postage £35 :shock: ) - Sorted
1x Gear lever with decent splines to cut up for rear sets
Cheers,
Phil.
** Special rates for the Z1OC forum members **
Website design, hosting / domain names.
Computer and Laptop repairs.
Jay1969
#2 PostAuthor: Jay1969 » Thu Dec 12, 2013 1:42 pm
Hi Phil, you can borrow my LH / RH switches from my Zed until it's
ready for rebuild if that helps? May even buy new pattern one's,
not decided yet. They are in good useable condition.
#3 PostAuthor: z1bman » Thu Dec 12, 2013 1:53 pm
£39.40
http://www.ebay.co.uk/itm/1973-1975-Kaw ... 3#shpCntId
tail light screws part no 220E0435A available at cradley
#4 PostAuthor: z1bman » Thu Dec 12, 2013 2:17 pm
tail light screws part no 220E0435A £2.41 each available from cradley
zpower
#5 PostAuthor: zpower » Thu Dec 12, 2013 4:24 pm
Thanks Jay will let you know mate.
Thank you z1bman.
Cam chain tensioner purchased :D
#6 PostAuthor: chrisu » Thu Dec 12, 2013 6:20 pm
pm me your address - carb top screw and side stand spring i can do
zpower
#7 PostAuthor: zpower » Thu Dec 12, 2013 7:18 pm
Thank you chrisu.
Much appreciated.
Redbeard
#8 PostAuthor: Redbeard » Thu Dec 12, 2013 8:51 pm
If someone can confirm it is the same, I have LH switchgear off a 1977 z750 twin you can have. Fairly certain they share the same switchgear??
Jay1969
#9 PostAuthor: Jay1969 » Thu Dec 12, 2013 9:12 pm
Redbeard, this is the L/H switch gear from my kz1000B2 LTD
to see if it matches to your z750 twin L/H switch gear.
Redbeard
#10 PostAuthor: Redbeard » Thu Dec 12, 2013 9:19 pm
cheers Jay, looks the same to me.
zpower
#11 PostAuthor: zpower » Fri Dec 20, 2013 4:14 pm
Thank you Redbeard :)
LH switch now sorted but RH with throttle still outstanding if anyone can help?
Cheers,
Phil.
