APE Degree Wheel & Positive Stop Tool
- Ginger Bear
Anybody got either of the above they're willing to sell?
Degree wheel: If youre using it on a J motor (or MKII / ST ) print off a paper one from the internet (OSP did have one for download) and glue it onto a piece of 18 gauge mild steel.
Cut round after and drill a 20 or so mm hole in the middle so it self centres.
No need to undo the rotor fixing bolt to use it and you can still use the bolt to turn the motor, it just sticks to the magnet body.
Cheap and satisfying.
martinz1000r
- Ginger Bear
