55mm pod filters.
KWACKERZ1
55mm pod filters.
#1 PostAuthor: KWACKERZ1 » Tue May 09, 2017 11:50 am
Anyone got any 55mm pod filters. they want to part with?
Z1parR
Re: 55mm pod filters.
#2 PostAuthor: Z1parR » Tue May 09, 2017 9:12 pm
I think i have a set here Phil , bear with me , they're not pretty but if i can find them then you can have them .
0172 . Geoff Parr
KWACKERZ1
#3 PostAuthor: KWACKERZ1 » Wed May 10, 2017 5:16 pm
Thanks Mate they.ll be hidden anyway, but could do with them asap if you could check for me.
8 Valve Mark
#4 PostAuthor: 8 Valve Mark » Fri May 12, 2017 9:51 pm
Search eBay for "55mm air filters" n you can get a set of 4 starting at £25...easy enough.. good luck
KWACKERZ1
#5 PostAuthor: KWACKERZ1 » Sat May 13, 2017 7:55 pm
yes have seen the 24 pound ones anyone know if they are any good?
I think I need foam type ones as space is a premium.
But thye are £80 :shock:
Julian_Boolean
#6 PostAuthor: Julian_Boolean » Sat May 13, 2017 8:51 pm
Don't get the cheapies, they usually block the air jet holes in the mouth of the carbs, I think my ram airs were about £75
